It is currently 243012UTC TueUTC2019-06-25T00:21:30+00:00 2018...17.52
Newbie
Come on in and say hello.
  • Author
  • Message
Offline
dave the rave
Site Admin
  • Joined: 243005UTC TueUTC2012-09-25T17:50:54+00:00 2018...17.52
Re: Newbie
Post243110UTC FriUTC2018-10-05T22:25:47+00:00 2018...17.52
120bhp isn't too problematic from a 1275. They can confidently go to 1400cc. A bit more on a stroked Marina crank ( 84mm ).
Offline
Rallyman
  • Joined: 243109UTC WedUTC2018-10-03T21:51:42+00:00 2018...17.52
Re: Newbie
Post243103UTC TueUTC2018-10-09T15:22:25+00:00 2018...17.52
Or would a triumph 1500 engine be a good idea?
Offline
dave the rave
Site Admin
Re: Newbie
Post243106UTC TueUTC2018-10-09T18:49:25+00:00 2018...17.52
Definitely NOT.......a rubbish engine. A stretch too far from its 1300 predecessor. Years ago i spent 16+ years grinding crankshafts, ( have just started again in a company that actually MAKES them from bare EN40B steel bar ). The amount of Triumph 1500s that came in that had the thrust very badly worn, big-ends knocked out and, worse of all, were cracked around one or more of the fillet rad of the big-end, was surprising. With the latter they're scrap. Journals and the thrust can be welded. They don't like high revs either. As i said, rubbish engine. I would'nt beg one.
Offline
Rallyman
Re: Newbie
Post243109UTC TueUTC2018-10-09T21:13:16+00:00 2018...17.52
Looks like I will have to find a marina 1300 engine then as 1275 are going for silly money
Offline
dave the rave
Site Admin
Re: Newbie
Post243109UTC TueUTC2018-10-09T21:51:04+00:00 2018...17.52
Bear in mind John, a Midget crank will fit straight into a Marina block. It'll need the Midget con-rods though. In my opinion, the only downside of the Marina blocks is the near upside down oil filter. Though remote filter kits are available.
Offline
stoney13
  • Joined: 243008UTC TueUTC2012-09-25T20:13:24+00:00 2018...17.52
Re: Newbie
Post243112UTC FriUTC2018-10-12T12:50:11+00:00 2018...17.52
hi rally man and welcome,if you like the mx5, then why not fit the 1.6/1.8 mazda and box, as you must be aware being an owner of the mx5 you can go with single turbo twin turbo's or even a super charger as the 1.6/1.8 has forged pistons and a decent crank, all you would need to do if fitting a super charger is to fit double head gasket to lower compression ratio. the Mazda engine and box only weigh a few pounds more than the a series and box also on the up side you can get all the bits you need for around £200.00.
best of luck with the restoration ;)
EMA KAY - racing ( A40 s/w group & Wessex group)
Offline
Rallyman
Re: Newbie
Post243103UTC FriUTC2018-10-12T15:39:19+00:00 2018...17.52
Hi
I would fit an mx5 engine but want to run in the historic class so will have to fit a period engine
Offline
stoney13
Re: Newbie
Post243108UTC SatUTC2018-10-13T20:06:46+00:00 2018...17.52
ha, you need a 998 cc for a sprite, or 1275 from the midget not that marina thing then ;)
Offline
Rallyman
Re: Newbie
Post243008UTC ThuUTC2018-11-08T20:48:03+00:00 2018...17.52
I am nit finding any 1275 engines for sensible prices so am considering going the 1500 route .can these engines be made reliable?
Offline
dave the rave
Site Admin
Re: Newbie
Post243010UTC ThuUTC2018-11-08T22:06:22+00:00 2018...17.52
The only way I'd ever consider a Triumph 1500 would be with an EN40B Nitrided crank and decent conrods. The crank being the main contender. And modified to take two thrust washers each side.
Previous
Return to Welcome
Who is online
Users browsing this forum: No registered users and 1 guest
cron
