It is currently 243107UTC SatUTC2019-03-23T19:26:34+00:00 2018...17.52
Engine ID?
Ben Morong
  • Joined: 243011UTC TueUTC2017-06-20T23:34:18+00:00 2018...17.52
Engine ID?
Post243003UTC SunUTC2018-04-15T15:11:42+00:00 2018...17.52
I've run across an unfamiliar (to me) engine, and wonder if someone could help ID it. Could it be an Austin 803 cc? Its serial number is 1G 926563 -- from that can someone tell when it was made and what it came in? I have some pictures of it which I could forward. I will be grateful for all help. Thanks. Ben M.
David Lewis
  • Joined: 242808UTC TueUTC2013-02-26T20:43:36+00:00 2018...17.52
Re: Engine ID?
Post243006UTC SunUTC2018-04-15T18:29:05+00:00 2018...17.52
Hello Ben,
Further to your query regarding the ID of the engine you have I would hazard a guess and say that the engine plate number you quote,( assuming that the number is stamped on the engine plate on the offside of the engine block top) may well be a Gold Seal engine number. In other words the engine has been subject to a BMC factory recondition and would therefore have been issued with a number other than it's original one. Any A30, 803 cc or early 948 cc A35 engine would have the engine prefix 2A . A40 948 engines would have engine prefix 9A or 9AB.
However a sure fire way to identify whether it is 948 cc is to look at the nearside of the engine block (ie manifold side) and there you will find in the block casting the figures '950' which indicate it's engine size. If the block is a later 1098 cc item then this is identified by a plate, rivetted, in roughly the same location with the legend '1100' thereon.
Check these pointers first and see if any match up.
Regards.
David Lewis.
  • Joined: 243005UTC TueUTC2012-09-25T17:34:53+00:00 2018...17.52
Re: Engine ID?
Post243009UTC SunUTC2018-04-15T21:17:36+00:00 2018...17.52
I can find no reference to 1G engine number prefix.if you could post some pics it would be a great help .
  • Joined: 243005UTC TueUTC2012-09-25T17:50:54+00:00 2018...17.52
Re: Engine ID?
Post243009UTC ThuUTC2018-04-19T09:44:22+00:00 2018...17.52
To my mind, starting 1G indicates a part number. But then there's too many individual numbers following. A part number would have a maximum of four. As Mike says, a photo would be very helpful.
Ben Morong
Re: Engine ID?
Post243006UTC SunUTC2018-04-22T18:09:59+00:00 2018...17.52
Mike & Dave: The owner sent me an email with pictures of the engine. One is attached, as I'm not sure whether this will work or not. If it does, I'll post again and attach the rest of them.
Ben Morong
Re: Engine ID?
Post243006UTC SunUTC2018-04-22T18:13:31+00:00 2018...17.52
OK, it worked. Here are the others.
Ben Morong
Re: Engine ID?
Post243006UTC SunUTC2018-04-22T18:20:10+00:00 2018...17.52
Mike & Dave: I also located a website called austinworks.com whose owner, Rob Stuart, says he has an A40 van built in September 1953 that has an engine with the serial number 1G 899xxx.
Re: Engine ID?
Post243006UTC SunUTC2018-04-22T18:51:20+00:00 2018...17.52
It's a pre BMC engine. That explains it. Actually could be an Austin 1200cc engine. Precursor to the BMC B Series. Original Austin number system i'd guess.
Re: Engine ID?
Post243008UTC SunUTC2018-04-22T20:03:35+00:00 2018...17.52
Definitely 1200cc Austin motor .The 1G prefix is correct .A40 Devon and possibly A40 Somerset.
What the engine in the photos was used for I don't know ,those engine mounts not Austin.
Users browsing this forum: No registered users and 4 guests
