agm 2022
Posted: 14 Jul 2022 18:25
by Stoney13
to all if you are travelling, please make sure that you check your levels including tyre pressures , please ensure that you and your travellers also have enough to drink, as its going to be hot this weekend, be safe
Re: agm 2022
Posted: 15 Jul 2022 07:46
... and if you get stuck in heavy traffic, set the heater control to Full, switch the blower on and open the windows. Obviously if the delay continues, turn the blower and the engine off.
Re: agm 2022
Posted: 15 Jul 2022 12:53
by exlkrs
Good old trick that Keith. Used it in Minis with the rad at the side many years ago. Having the heater on full and sending water around the heater system dissipates the heat providing a little respite for your hard worked motor!
