Page 1 of 2
Frozen North.
Posted: 11 Jan 2025 11:14
by exlkrs
Minus Eight last night!!
Re: Frozen North.
Posted: 11 Jan 2025 12:27
by Mike Hodgson
A few years ago I was working in South Glos. at -35c .
Re: Frozen North.
Posted: 11 Jan 2025 14:27
Riley ‘O Blimeys….. :o :roll: :twisted:
Re: Frozen North.
Posted: 11 Jan 2025 15:47
by austina40sam
Sure is cold Chris
Re: Frozen North.
Posted: 11 Jan 2025 16:31
by Mike Hodgson
And this was during May Dave .
Correction
Just double checked it was in September.
Re: Frozen North.
Posted: 11 Jan 2025 18:59
Quite scary in Banbury tonight when I collected Bar from church at 6pm - freezing fog and some icy stretches around the local estate roads. Wipers not much use and oncoming "moderns' " headlights so bright Gab was reduced to walking speed (not popular with the 4x4s behind me but then, I was in front, so screw 'em!)
Re: Frozen North.
Posted: 11 Jan 2025 19:40
by Mike Hodgson
WE have been lucky here in North Dorset.A light dusting of snow three days ago that disappeared quickly ,quite cold but the days have been sunny enough for the solar panels to give a good output.
Re: Frozen North.
Posted: 13 Jan 2025 12:40
by austina40sam
Blimy Mike, when was that? That really is cold for Sept! Sounds like you have had it pretty bad where you are! The town of Seaford has been okay snow wise however all around did have snow. I was waiting for an hour nearly for the bus home from work. Waited half an hour for the bus in the cold then decided i would go over the road to the pub for a drink and a warm up. Bus did come in the end and i had no trouble getting home. Hope you and Bar are keeping warm enough in this weather. Same for you and Mrs H Mike.
Re: Frozen North.ow
Posted: 13 Jan 2025 17:03
by Mike Hodgson
Sam .I did say I worked in that temp. which was true.It was in a very large fridge used to freeze down a complete aero engine with fuel and two 24volt batterys to carry out cold start tests.
Re: Frozen North.
Posted: 14 Jan 2025 12:37
by austina40sam
HI Mike, That is so interesting, what a wonderful job that must have been for you.
