Potential Problem....
Posted: 26 Feb 2026 16:58
by exlkrs
Today, I've inadvertently worked on my Morris Traveller whilst wearing my Austin hat. Will bad things happen or am I covered by BMC immunity?
Re: Potential Problem....
Posted: 26 Feb 2026 18:56
Not entirely sure the Moggie's woodworm will show much respect for that Austin badge!!
Posted: 26 Feb 2026 19:28
Ooooh, dodgy ground ‘ere dude…..
Posted: 27 Feb 2026 09:29
by TimB
exlkrs wrote: ↑26 Feb 2026 16:58
I'm pretty sure you're covered. It might be worth a quick check with the Monopolies and Mergers Commission, just to be sure.
Posted: 27 Feb 2026 14:58
I might suggest adding a splash of Rentokill to the water next time you wash the Moggie . . . ?
. . . but on second thoughts . . . !
Posted: 01 Mar 2026 10:43
by austina40sam
What you been doing to it Chris?
Posted: 01 Mar 2026 14:51
by exlkrs
austina40sam wrote: ↑01 Mar 2026 10:43
Just a bit of fettling for the season Sam, clutch adjustment, shiny new grille panel. and a bit of Lanoguard. A40 next - new engine I think. Always had low oil pressure, but rattling its mains off when you start it up now. Shame as it ticks over and runs so sweetly.
Posted: 04 Mar 2026 20:24
by austina40sam
Have you found an engine for the A40?
Posted: 05 Mar 2026 08:20
by exlkrs
austina40sam wrote: ↑04 Mar 2026 20:24
Not yet Sam, but do have a couple of leads to follow up.
Posted: 05 Mar 2026 08:50
I had an old MkI Cortina auto years back, it was up on bricks and I paid £10 for it. The bearings rattled away when you went around corners, all it needed was time for the oil to catch up and sweet as a nut to drive. Used it for 3 years until the body rotted away, cheapest car I ever owned. Once the oil gets to do it's work they go for ages the old ones. Todays motors stop instantly if they get a bit of dust in a sensor.
