Hammerite
Posted: 21 Dec 2020 21:29
by exlkrs
Mixing Hammerite to be exact. I want to mix black and red to make Maroon. Anyone tried. Their website says don't mix it. That said, it's not clear - does it mean don't mix it with other stuff? (Fair enough), or don't mix it with itself?
Re: Hammerite
Posted: 21 Dec 2020 22:42
by Dave the rave
Obviously they don't do Maroon then, as it would have been on their website. I'm surprised actually. To answer your question, I can't see a problem mixing two Hammerites. Unless it's something to do with the colouring pigments....or whatever it is that's used to obtain the colour. ( I'd go for the smooth version, I think it looks much better ).
Re: Hammerite
Posted: 22 Dec 2020 08:34
When mixing colours, always add the darker pigment to the lighter one - you'll use gallons unnecessarily if you try lightening black paint! And try to keep a note of roughly what proportions went into the mix just in case you need to match the colour at a future date.
Re: Hammerite
Posted: 22 Dec 2020 08:59
by Stoney13
yes you can mix hammerite colours amd if you are spraying it mix it 50/50 with cellulose thinners, you can also wash every thing out with cellly thinners
Re: Hammerite
Posted: 22 Dec 2020 15:53
But really only in a well-ventilated area.
