Videos
Posted: 04 Jul 2020 21:13
by Mike Hodgson
Re: Videos
Posted: 05 Jul 2020 21:17
by Colin Wells
Mike, your bench test video - there's a hose connected into the thermostat housing which appears to go round to the heater valve area, but the water pump hose is not connected. Can we assume you had no coolant in for the run?
Re: Videos
Posted: 05 Jul 2020 21:56
by Mike Hodgson
Correct Colin no coolant ,as you can see it was only run for a few seconds at idle and then transferred to static test rig with cooling system for longer runs .I have a video of that somewhere must find it.The pipe in top hose was just pushed in to stop it flapping about.
Re: Videos
Posted: 07 Jul 2020 08:45
by Chairman Ed
Mike, thank you so much for posting these.
Just watched the first one The Home Made Car.
I recall seeing it in the TV many years ago.
Re: Videos
Posted: 14 Jul 2020 18:42
by austina40sam
Thank you so much for posting these Mike, I really enjoyed watching them.
Re: Videos
Posted: 09 Jan 2021 16:38
by Mike Hodgson
Found the static test bed video------
https://youtu.be/FuhR_dHnX6U
Re: Videos
Posted: 13 Jan 2021 12:48
by Stoney13
very good mike could of given it a rev or two
