rear suspension
Posted: 25 May 2022 11:32
by THE 70S
hello, i am in the process of restoring a 642 lvo i have a history file which indicates it was restored in 2003 by a member from nottinghamshire who did a fabulous job.Im just refurbishing the rear suspension i have a problem one of the rear springs has the same dimension opening at both ends so the front bush 3h2103 is to small.The spring is identical in other dimensions to the one with the correct bush,... any ideas what the correct bush should be? regards kevin
Re: rear suspension
Posted: 26 May 2022 11:26
( Bumped to front page).
