Still 25 thou......? ?
Post by Dave the rave » 16 Jun 2020 12:16
No excuse at the moment for not checking your sump-plug gaps......
Re: Still 25 thou......? ?
Post by Keith Bennett » 16 Jun 2020 19:22
D'oh! Which bright spark thought of that??
Post by Stoney13 » 17 Jun 2020 10:24
champion ;) ;) ;)
Post by Mike Hodgson » 17 Jun 2020 11:02
I think it is just "Lodged" in
philcwebb
Post by philcwebb » 17 Jun 2020 20:50
Having spent more time yesterday trying to get the gearbox filler plug back in through that access hole in the tunnel without dropping it on the floor than the exercise of getting oil in the hole I actually think a plug with a long extension is a great idea!
Post by scotty » 18 Jun 2020 08:31
Could be wired up as a sump heater for the winter
Post by austina40sam » 18 Jun 2020 08:55
That has cracked me right up along with peoples replies!! Phill, I know just what you mean, that is what I am always doing dropping the plug on the floor! Amazingly last time I checked g/box level I managed to fit the plug first time!
Post by Dave the rave » 19 Jun 2020 14:39
Simple solution there, make a new BIGGER access panel with some self tappers.
Post by Mike Hodgson » 19 Jun 2020 14:46
Even simpler.
Place a short piece of string across socket push g/box bung in socket ,string should be enough to grip bung allowing you to poke socket with bung through access hole install and just pull/waggle socket away releasing the grip of the string .
Used this method many times and it works first time every time .
philcwebb
Post by philcwebb » 19 Jun 2020 15:02
After 'muttering' several times brain engaged and I remembered that some time ago I bought one of those magnets on an extending arm from one of those 'got everything here somewhere' stalls at the NEC. Even found it quickly - put plug on end of magnet and it was good enough to start the tread off. (Now just need to keep it somewhere I can find it for next time!)
