New Garage Find - Suffolk
Re: New Garage Find - Suffolk
Looking very nice. Do check the bases of the rear light clusters have their drain hole clear - and don't forget to run the rubber tubes down to, and through the boot floor and into fresh air.
Looking really good after all your work.
Finally in the paint booth!
Keith - drain holes all clear and tubes in the spares pile to be installed!
Underside seam sealed - next stop same in the engine bay and then non stop painting!
More progress - seam sealing completed and first epoxy primer coat.
Its looking good. Keep up the good work.
Do I see steering rack mounts in there?
Scotty - I hope nothing is missing as car is going to be a stock rebuild.
Painting is continuing!
