https://youtu.be/bqMb4W3UBoo
https://youtu.be/uSCAxfik1wU
https://youtu.be/WeuSOxrMI9A
https://youtu.be/nI-VoiycK5U
https://youtu.be/DXhLkm0Jf8I
https://youtu.be/1gFKbXD7H_E
https://youtu.be/T3zZ_hXsFUg
https://youtu.be/3U4tzYv2vkI
Videos
- Colin Wells
Re: Videos
Mike, your bench test video - there's a hose connected into the thermostat housing which appears to go round to the heater valve area, but the water pump hose is not connected. Can we assume you had no coolant in for the run?
Re: Videos
Correct Colin no coolant ,as you can see it was only run for a few seconds at idle and then transferred to static test rig with cooling system for longer runs .I have a video of that somewhere must find it.The pipe in top hose was just pushed in to stop it flapping about.
Chairman Ed
Re: Videos
Mike, thank you so much for posting these.
Just watched the first one The Home Made Car.
I recall seeing it in the TV many years ago.
Re: Videos
Thank you so much for posting these Mike, I really enjoyed watching them.
Re: Videos
Found the static test bed video------
https://youtu.be/FuhR_dHnX6U
Re: Videos
very good mike could of given it a rev or two
