New Garage Find - Suffolk
Re: New Garage Find - Suffolk
Post by exlkrs » 09 Mar 2025 21:10
Great job. Super panel gaps. I'd be well pleased with those!!
Spiney4
Post by Spiney4 » 14 Mar 2025 14:08
Been to look at the car today - now onto the back starting with the spring hangers that are past their best!
Spiney4
Post by Spiney4 » 14 Mar 2025 14:14
Have also sourced 2 NOS MK1 rear Qtr panels - not easy to find!
Post by scotty » 14 Mar 2025 15:20
Nice find. All the work looks really good.
Post by Keith Bennett » 18 Mar 2025 19:28
Be advised that connecting the top seam to the lower seam beneath the side windows upper panel can test the patience of a saint. The joint comprises interlocking lips and I believe that the two panels were assembled before being added to the shell as a single unit.
Spiney4
Post by Spiney4 » 26 Mar 2025 17:11
Thanks Keith - will bear that in mind. Car rear floor is now being worked on - Chassis legs need a fair bit of new fabrication as the originals were rather open to the elements so have rotted out or metal has blown. New Spring hangers have also been fabricated as unfortunately sourcing an A35 pair didn't resolve matters.
Post by scotty » 26 Mar 2025 17:46
Keith Bennett wrote:
18 Mar 2025 19:28
You will find a picture of the fully welded joint on ‘UCE 13, Scotty’s race car’ on the first page. This join was originally spot welded and if the paint cracks water enters the gutter like panel join which runs down the back and rot the bottom corner of the rear window, bottom corner of boot opening and down to the rear spring hangers. Hard work but worth the effort.
Managed to copy so posted
Post by Keith Bennett » 27 Mar 2025 16:45
Good work Scotty. I had the privilege of watching the welder at work closing the joint. Seems this wasn't done during manufacture but UCE 13's shell needed to be as stiff as possible to withstand the stresses of the race circuit.
Spiney4
Post by Spiney4 » 15 May 2025 16:07
Latest update - significant repairs needed to the chassis legs and rear floor - been strengthened and rebuilt with some donor parts - very fiddly, time consuming and an expensive job! Next job is the inner and outer rear wings!
Post by scotty » 15 May 2025 19:20
Looking really good.
