Hello, I’m new here
Hello, I’m new here
I’m looking for electronic ignition, do i need to change my wiring if i do this.
Re: hellow im new here
Hi Edward, welcome to the madhouse and thanks for keeping another A40 on the road. Is it a saloon or Countryman, and what year is the old girl?
It’s s a 1959 Mk1 saloon left hand drive. i also need the brake line that goes to the rear axle. i was hoping to get one that is braided.
Re: Hello, I’m new here
Regarding electronic ignition the simplest version is to keep everything except the points and condenser in the distributor and just replace these with the electronic unit.
Several kits are available that come with wiring instructions - just do an online search and several will come up.
Just be sure to specify that it's for a positive earth system - assuming your A40 hasn't been converted to negative earth.
1964 A40 Farina Deluxe, Horizon Blue, Black Roof, 1098cc engine
Hello! Welcome. You can usually find help with problems here, so you're never alone with an A40!!
