Spiney4
Post by Spiney4 » 15 Feb 2026 15:22
Nearly ready for first primer coat....
Post by Keith Bennett » 15 Feb 2026 20:41
Looking very nice. Do check the bases of the rear light clusters have their drain hole clear - and don't forget to run the rubber tubes down to, and through the boot floor and into fresh air.
Post by scotty » 16 Feb 2026 09:30
Looking really good after all your work.
Spiney4
Post by Spiney4 » 22 Feb 2026 12:06
Finally in the paint booth!
Keith - drain holes all clear and tubes in the spares pile to be installed!
Spiney4
Post by Spiney4 » 25 Feb 2026 10:09
Underside seam sealed - next stop same in the engine bay and then non stop painting!
Spiney4
Post by Spiney4 » 28 Feb 2026 10:41
More progress - seam sealing completed and first epoxy primer coat.
Post by austina40sam » 01 Mar 2026 10:45
Its looking good. Keep up the good work.
Post by scotty » 02 Mar 2026 09:02
Do I see steering rack mounts in there?
Spiney4
Post by Spiney4 » 12 Mar 2026 11:01
Scotty - I hope nothing is missing as car is going to be a stock rebuild.
Painting is continuing!
Spiney4
Post by Spiney4 » 10 Apr 2026 11:33
Top Coat (farina grey) at last!
