Non motoring what is it
Post by Mike Hodgson » 02 Jun 2020 17:46
Altho it is a non motoring item it was a freeby to some customers from this motor factor.
I think it is from 50/60s and is unused.
Midlife
Re: Non motoring what is it
Post by Midlife » 02 Jun 2020 18:42
Is it some sort of paper dispenser?
Post by Mike Hodgson » 02 Jun 2020 19:43
Midlife wrote:
02 Jun 2020 18:42
Fraid not no paper but metal is involved
Midlife
Post by Midlife » 02 Jun 2020 22:20
Razor blade dispenser?
Post by Mike Hodgson » 02 Jun 2020 22:35
Midlife wrote:
02 Jun 2020 22:20
You are very very close ,it's not a dispenser
Post by Keith Bennett » 03 Jun 2020 08:57
Look, the label on the box gives it away - even I can tell it's a Ferrari piston. Honestly, wot a give-away.
Midlife
Post by Midlife » 03 Jun 2020 09:40
So that's how they make Ferrari pistons....
Post by Stoney13 » 03 Jun 2020 09:45
pencil sharpener ??
Graham Bish
Post by Graham Bish » 03 Jun 2020 10:03
I'ts a Razor Blade Sharpener!
The manufacturer was Buck & Abbott Ltd of Preston, Lancashire. Insert the blade, turn the handle guess around 1950s.
Ferraris Piston Services are better known as FPS Distribution. They where part of Lookers until a few years ago. They run those distinctive Peppermint Green delivery vans.
Post by Mike Hodgson » 03 Jun 2020 10:36
Graham Bish wrote:
03 Jun 2020 10:03
Spot on .The internals consist of a pair of contra rotating cylindrical strops and the gearing flips the blade over at the end of a rotation so both sides of the blade are honed.
