motoring what are they
Post by Mike Hodgson » 05 Jun 2020 15:47
Midlife
Re: motoring what are they
Post by Midlife » 05 Jun 2020 18:28
Are they for clearing/cleaning engine block waterways? Judging by the size of the worn teeth at one end, not a precision engineering tool.
Post by Mike Hodgson » 05 Jun 2020 19:34
No not for cleaning water passages and yes they are well worn and have limited if any use on modern cars.
Post by Keith Bennett » 05 Jun 2020 20:12
Carburettor cleaners then?
Post by Mike Hodgson » 05 Jun 2020 20:35
Keith Bennett wrote:
05 Jun 2020 20:12
No
Post by Keith Bennett » 06 Jun 2020 09:11
Steam car burners' cleaners then?
Post by Mike Hodgson » 06 Jun 2020 09:39
06 Jun 2020 09:11
No
They are a great help when dismantling some types of older engines
Post by Stoney13 » 06 Jun 2020 10:32
bearing or seal removers ??
monty
Post by monty » 06 Jun 2020 11:40
I have a vauge recollection of a similer looking tool being used to free up castings when goo or corossion had locked the casting to its mounting studs, inthis case the tool wall was thin sothat it could go over the stud and down the clearence hole. Also a thicker walled version used to cut down thesurface face when a stud had been over tightened and started to pullup the surface.
Post by Mike Hodgson » 06 Jun 2020 12:11
Stoney13 wrote:
06 Jun 2020 10:32
No Steve
they are 3 different diameters 3/8" , 7/16" and 1/2"
Answer later
