Videos
Colin Wells
Re: Videos
Post by Colin Wells » 05 Jul 2020 21:17
Mike, your bench test video - there's a hose connected into the thermostat housing which appears to go round to the heater valve area, but the water pump hose is not connected. Can we assume you had no coolant in for the run?
Re: Videos
Post by Mike Hodgson » 05 Jul 2020 21:56
Correct Colin no coolant ,as you can see it was only run for a few seconds at idle and then transferred to static test rig with cooling system for longer runs .I have a video of that somewhere must find it.The pipe in top hose was just pushed in to stop it flapping about.
Chairman Ed
Re: Videos
Post by Chairman Ed » 07 Jul 2020 08:45
Mike, thank you so much for posting these.
Just watched the first one The Home Made Car.
I recall seeing it in the TV many years ago.
Re: Videos
Post by austina40sam » 14 Jul 2020 18:42
Thank you so much for posting these Mike, I really enjoyed watching them.
Re: Videos
Post by Mike Hodgson » 09 Jan 2021 16:38
Found the static test bed video------
https://youtu.be/FuhR_dHnX6U
Re: Videos
Post by Stoney13 » 13 Jan 2021 12:48
very good mike could of given it a rev or two
